Hi all,
Picked up an 01 Dakota. It had two codes when I got it. PO442 and PO455. I got the PO455 to go away (loose filler hoses and fuel pump nut) but have not been able to track down the PO442. I have smoke tested it and have not found any leaks (I have inspected top of tank when smoke testing with my camera phone. Maybe I need to pull the tank down so I can see it with the naked eye). The purge valve did seem a bit lazy so I replaced it. LDP seems good based on my bench test. I also replaced all rubber hoses and the fuel cap (Mopar OEM) as a precaution (charcoal canister, under hood, etc). What could I be missing? Any help would be appreciated.
